App version: 2.13 (Google Play)
Android version: 10
Device model: Galaxy A10
Expected behaviour: Anything at all!
Current behaviour: App crashes during startup every time
First occurred: Today
Environment: No settings have been changed, no updates downloaded, it worked fine yesterday but not today.
There is no crash report in /Android/data/de.danoeh.antennapod
Any ideas on what to do or how to find out more?
The crash is caused by a bug in the app “Android System WebView”. The bug makes several different apps crash, including AntennaPod. Google has already released a bug fix update. Have a look at the Play Store to see if you are running the latest version of “Android System WebView”.
If you don’t see the update yet, you can also try uninstalling the updates of that system app. In the long run, you want to use an up-to-date version of that app, though.
Below you can find a chart with the number of AntennaPod crashes on the past few days. Looks like most users got the “Android System WebView” update now - the number of crashes is nearly back to normal.
Thank you for this. Yes, this was my problem too.
