Local Folder Multi Select Delete not Working
App version: 3.9.0-beta1
Android version: 12
Device model: SM-G975F
Deleting files in a local folder by tapping the delete button of the ‘Multi select’ pop-up box should delete the selected files.
Selecting ‘Delete’ after having initiated ‘Multi select’ in a local folder does nothing, whether one file is highlighted or many.
First occurred: I don’t know. Just noticed it today.
  1. In AP, open a local folder containing multiple AP compatible audio files.
  2. Long press on a file and choose ‘Multi select’, which highlights that file.
  3. Choose ‘Delete’ from the popup box.
  4. Take note that the file was not deleted and remains highlighted.
  5. Highlight (by selecting) multiple files and attempt to delete them.
  6. Take note that the files are not deleted and remain highlighted.
Crash info: No crash report recorded
Same behavior for me.
Same issue on my end!
