Podcasts skipping back and over content during stream
Life Hack!
I won’t make you go read all my posts above so I am going to summarize what I have experienced.
  1. I am using the F-Droid version
  2. This issue only happens on podcasts that have ads inserted.
  3. I don’t stream the podcasts. I always download.
  4. When it happens, I delete the episode and redownload it and the problem does not appear for that particular episode.
    On accident I found a trick that works
    If podcast skips, I rewind and then hit pause, let it sit for 5 seconds, press play and boom, it doesn’t skip again.
3.5.0f (300baf6dd)
Android 10
Same problem happens to me.
All episodes downloaded.
Sometimes repeats a section 2 or 3 times.
I have the Pixel 8 Pro also. Same issue. I’ve uninstalled and reinstalled the app- will see if that helps.
Came looking for answers. Another Google refugee. I am listening on a Samsung Galaxy S22 Ultra
I normally listen (stream) while driving, so I’m sure there are moments between towers & dead spots where connection is halted.
Semi-regular instances of sudden skip-backs, replaying a section. Does NOT seem to coincide w/Ad breaks. Whatever time is repeated is then missed at the end of the episode, so if it happens too much, you lose more than the closing credits.
Still seeing this problem on a OnePlus Nord running Android 12, with AntennaPod 3.5.0 (300baf6dd) installed from Google Play (I think)
I only stream pods, typically from the episode list in the subscriptions section. I never download. I’ve seen the problem with various podcasts including The News Agents (Global), The Rest Is Politics (Goalhanger), The Rest is Money (Goalhanger), and Talking Politics (ITV News).
I am also experiencing this issue.
I mostly stream episodes via wifi and data. I’ve had this happen with several podcasts. some examples: Lore, No Dogs in Space, Ongoing History of New Music.
Sometimes it skips forward, sometimes back.
It seems to be happening in podcasts that are trying to insert ads.
Samsung Galaxy A52S
AntennaPod version 3.5.0 (300baf6dd)
Android 14
Same issue as others described.
Android 13
Pixel 4a
Version 3.6.1 (8ec7d08e2)
Pixel 8 pro, android 15
I have been having the issue for a long time and still have it. I usually force close the app, clear the cache and then start it again, that solves the issue. However even if that solves the issue I sometimes have trouble finding where the skip happened and have to seek a bit forwards and backwards before finding where I were. I listen to several podcasts with ads however I don’t know if those ads are injected on the fly.
This happens to me both when streaming and in downloaded podcasts. It is not limited to certain creators but happens in all of the podcasts I consume. Sometimes it happens multiple times per episode. Initially I thought perhaps something I was doing was triggering the behavior but realized it was not user error/behavior.
Android Version: 15
App Version: 3.6.1
Model: Pixel 8a
Same
Same issue as others described. Nothing I do fixes the skipping and I can’t take it anymore. I’m about to jump ship on this app. No other podcast app i’ve tried does this, so it can’t be that hard to crack.
AntennaPod version 3.6.1 (8ec7d08e2)
Android 14
Samsung Galaxy Flip5
Still happening for me also.
3.6.1 (8ec7d08e2)
Oppo find x
Android 13
I first thought this was an Android Auto issue, but it happened while taking the dog for a walk. Then I thought it was an Antennapod issue so I switched to listening to podcasts on YouTube Music Premium, and the same thing is happening on there. So the grass isn’t greener on the other side.
Antennapod stats
  • Version 3.6.1
  • Google Play
  • Android 14
  • Samsung S23
Had the same problem today. Happend only when streaming the Podcast.
Tried it in a different Player (Podcast Republic), here the problem die mit occur.
Downloading the episode in Atennapod solved the problem.
If helpful, I can provide Info which podcast episode and which Minute
I have the same problem on my pixel 9…
Pixel 8 Pro. Same problem with some additional quirks. It started as just jarring/random skips in audio and more recently it will just refuse to play at some point. It will sometimes not be able to finish a podcast when its close to the end, but maybe this is just coincidence. In case its helpful, I play my podcasts at 1.2x speed, could this be a contributing factor? My typical use case is also through Android Auto
I have observed these symptoms as well, though I don’t know if it’s related to the “Podcasts skipping back and over content during stream” issue.
What happens once in a while: The moment I click the 1.25 preset or Skip Silence button (and especially when I click both) the audio goes to an electronic buzzing noise. I can’t tell if that’s a distortion of the actual audio or just replaces the actual audio. Stopping playback stops the noise but starting playback resumes the noise. I get it working again by start/stopping playback from the Queue menu.
My setup: Pixel 9 Pro, episodes are usually downloaded, playback at 1.25x speed with Skip Silence enabled. I never use Android Auto, and in fact have never observed this in the car since I never change the speed settings while in the car.
Hi, l have the same problem and have had for months. I love open source software but for now I’m going to switch apps. I don’t mind missing banter and jibbajab, but most of the podcasts l follow have very little of that.
Also same issue with various podcasts. Just now with stuff you should know.
Same issue here. Today I tried listening to a podcast, but it was a nightmare. Sometimes, AntennaPod jumped back and forth 2-3x in 5 minutes!
Just created an account to say that I’ve been experiencing this issue since I first moved to this app from Google Podcasts. I’m on a Pixel 6a and mostly stream rather than download, but I think it happens with both. Fairly sure it doesn’t happen with podcasts that don’t have ads.
I’m going to pay closer attention for a few weeks and report any findings.
It would also be good to know if there might be something in the pipeline to fix this, as I don’t want to change apps but I will have to eventually.
