Refresh continuously
Hello dear technicians.
Since the newest update a few days ago, my app cant stop refreshing all my podcasts, all the time.
This is completely NOT necessary and it eats all my battery within 1-2 hours.
It was not the case before, and there is no stop button anywhere for this.
Urgent help needed.
Susan, in Germany.
What is your Refresh podcasts setting in Settings | Downloads? For example, I have mine set to every 4 hours. Not saying that is the source of the problem but knowing what your setting is currently at may help determine if this is a repeatable bug.
Thank you for answering.
My setting is never.
I refresh only when I choose, i.e. when I open Antennapod, proactively.
I found this solution for now : I cut WiFi+ mobile connection completely. After 2-3 min I had an error message.
When I was connected again, the refreshing had stopped.
As a first stab at fixing this I suggest doing a Force Stop and Clear Cache (do not Clear Memory).
If you encounter the issue again, take a screen shot of the message, it will be helpful when troubleshooting the issue.
At some point the option ‘Time of day’ refresh option was removed, but I wonder when (I can’t find back the relevant PR). I wanted to double-check which option users were moved to at that point.
They were moved to the default, which I’m pretty sure is “every 12 hours”
