App version: 3.4.0 (Google Play)
Android version: 11
Expected behaviour: E.g., the query snow white should be interpreted as snow AND white.
Current behaviour: The app searches for snow OR white.
Android version: 11
The search function does use “AND”. Because it searches in both title and description, long descriptions might contain many matched words
Just a thought: How does the search interpret “SNOW WHITE”? That is you put the search string within quotes?
Quotes are ignored as far as I know. It just searches episodes containing all words
Thanks for the clarification, @ByteHamster. If that’s the case, then I guess the next best thing is adding sort then advanced search. Having said that, I guess a relevance sort as default, ranking higher results closer to the search string order and proximity, might go some way in… providing more relevant results.
