Static when changing speed during playback
App version: 3.8.0
Android version: 12
Google Pixel 31
Can change speed any time, and playback continues at specified new speed
When changing speed during playback, either faster or slower, about half the time the sound file becomes continuous static. Playback continues according to GUI, but I hear only static.
At least a few months ago. Took me a while to think of submitting a bug report.
  1. Play a podcast in AntennaPod
  2. Tap speed icon in bottom-left
  3. Choose a speed
This is with Silence Removal turned on. My two most common speeds are 2.1 and 3, and I can get this problem when going from 2.1 to 3 and from 3 to 2.1.
I have experienced this issue too, especially with Skip Silence enabled.
I have the same problem - static When changing speed on the app using android auto
I continue to have this problem. Maybe less often than in the past. Android with and without Bluetooth headphones. Skip Silence enabled.
