Another version is in prep! Here’s a manual, list of changes in 2.4.0 that users should maybe know about, based on a 2.3.2 vs develop commit comparison, in chronological order of the commits.
List of PRs that were merged
| PR | author | title |
| #5235 | ueen | Allow to copy email address from shownotes |
| #5036 | peakvalleytech | Hide keyboard when not searching in settings |
| #5130 | peakvalleytech | Introduce multi-select & actions for episode lists |
| #5253 | peakvalleytech | Introduce multi-select & actions for episode lists (2) |
| #5184 | FarzanKh | Update download icon |
| #4839 | tonytamsf | Better de-duplicate episodes (based on unique ID, media url or title) |
| #5264 | ByteHamster | Ignore pull-to-refresh when there is no network |
| #5265 | ByteHamster | Update ‘visit website’ icon |
| #5266 | ByteHamster | Introduce multi-select & actions for episode lists (3) |
| #4833 | Thom-Merrilin, ByteHamster | Check podcast’s Auto Download preference before auto-downloading (and remove option from episode context menu) |
| #4722 | tonytamsf | Improve behaviour on bluetooth and headphone disconnect |
| #5268 | ByteHamster | Remove ‘visit website’ from episode context menu |
| #5191 | ueen, ByteHamster | Introcude swipe actions on podcast’s episode lists |
| #5271 | ByteHamster | Introcude swipe actions on podcast’s episode lists (2) |
| #5274 | tonytamsf | Better de-duplicate episodes (based on unique ID, media url or title) (2) |
| #5277 | jhenninger | Fix pull-to-refresh not working on empty queue |
| #5279 | ByteHamster | Better de-duplicate episodes (based on unique ID, media url or title) (3) |
| #5294 | ByteHamster | Show speed dialog on single click |
| #5296 | ByteHamster | Update ‘synchronisation’ icon in settings |
| #5308 | ByteHamster | Remove image cache size setting and choose size automatically |
| #5311 | ByteHamster | Adapt wording: remove last occurance of ‘feed’ and replace with ‘podcast’ |
| #5309 | ByteHamster | Remove left/right volume controls in audio settings |
| #5315 | ByteHamster | Fix crash when setting sleep timer to zero |
| #5317 | ByteHamster | Remove image cache size setting and choose size automatically (2) |
| #5321 | ByteHamster | Improve chapter mark support (skip id3 extended header if present) |
| #5329 | ByteHamster | Introduce support for subscription deeplink (cf Create an 'Open in AntennaPod' link – AntennaPod) |
| #5330 | ByteHamster | Display correct episode info in notification when continuous playback is disabled |
| #5335 | ByteHamster | Fix shownotes of multiple episodes being printed on top of each-other in subscription view |
| #5336 | ByteHamster | Fix slow restarting of episode after long pause if queue is long |
| #5338 | ByteHamster | Add search option to subscriptions screen |
| #5341 | myslok | Fix podcast cover being shown after adding a new tag |
| #5281 | vbh | Make accidental pull-to-refresh less likely |
| #5348 | ByteHamster | Fix adding new password protected podcasts |
| #5344 | vbh | Allow to tag a podcast from podcast contextual side menu |
| #5326 | thrillfall | Fix episodes not being marked as played in some cases when syncing with gPodder (relies on gPodder.net PR, though) |
| #5351 | ByteHamster | Move queue lock feature to the overflow menu |
| #5261 | peakvalleytech | Introduce multi-select & actions for the Subscriptions screen |
| #5358 | ByteHamster | Better de-duplicate episodes (based on unique ID, media url or title) (4) |
| #5361 | ByteHamster | Only change item state if it is actually in the inbox ?? |
| #5365 | ByteHamster | Hide keyboard when not searching in settings (2) |
| #5366 | ByteHamster | Introcude swipe actions on podcast’s episode lists (3) |
| #5387 | ByteHamster | Better de-duplicate episodes (based on unique ID, media url or title) (5) |
| #5189 | ueen | Behind-the-scenes code improvements |
| #5221 | hannesa2 | Behind-the-scenes code improvements |
| #5200 | TacoTheDank | Behind-the-scenes code improvements |
| #5312 | ByteHamster | Behind-the-scenes code improvements |
| #5310 | ByteHamster | Behind-the-scenes code improvements |
| #5355 | TacoTheDank | Behind-the-scenes code improvements |
| #5356 | thrillfall | Behind-the-scenes code improvements (sync) |
| #5357 | ByteHamster | Behind-the-scenes code improvements (sync) |
| #5359 | ByteHamster | Behind-the-scenes code improvements |
| #5360 | ByteHamster | Behind-the-scenes code improvements |
| #5362 | ByteHamster | Behind-the-scenes code improvements |
| #5364 | ByteHamster | Behind-the-scenes code improvements |
| #5369 | TacoTheDank | Behind-the-scenes code improvements |
| #5370 | TacoTheDank | Behind-the-scenes code improvements |
| #5372 | TacoTheDank | Behind-the-scenes code improvements |
| #5368 | TacoTheDank | Behind-the-scenes code improvements |
| #5383 | ByteHamster | Introduce swipe actions on podcast’s episode lists (5) |
Now moving on to make a curated list of noteworthy changes.
Can be updated if someone finds a good text but can also be kept.
